Hard time starting in the cold
Colliedog3
Waxhaw NC
I have a 73 bronco with a edelbrock 4 barrel with a manual choke and it doesn’t like to start in the cold. It doesn’t matter if the choke is open or close it barely starts. It also starts fine after it is warm. Any ideas on what could be wrong?
When it doesn't want to start, what exactly is it doing?
When you're closing the choke, do you close it all the way or close it, then open it back up a slight amount before trying to start?
trekgurl
I never had any luck with chokes other than the one I used to have cause a fire. After that, I threw choke away. and use the ole school "Ford"starting method my Uncle taught me. Two good hard pumps and then 1/2 pump, then crank ( sounds dirty don't it,, ;D,,,,,and it works about 98% of the time. Without the choke you have to "feather" the engine until it warms up. If you young and in a big damn hurry this won't work for you,, :) and I'm just not in that big of a hurry.
Yesterday I cranked mine (it sat for month and half),, (you really got pump the accelerator many times to get the gas up to the carb) and it fired right up.
The one thing I think that has helped my old engine is the mechanic who helps me put the electronic points in it and that really helped. It made big difference in the "cold nature" of my bronco. They're all different though and sometimes you just gotta hold your mouth right
