column and dash flasher switches
jcb9089
might be a dumb question, but I have an aftermarket tilt column with hazard switch and my dash also has hazard switch.
would hooking up both cause any issues? Thanks!
thegreatjustino
Red Head Grease Monkey
Stockton, CA
Interested to see what people say. I have the same setup but my dash switch was disconnected when the aftermarket column was installed. Only the column switch activates the hazards now.
surfer-b
It could be done, But, the 2 switches will have to be run parallel and require that you splice these wires. The W-R, W-BL, R-BLK, and the GRN-W. Look at this diagram, what you will do is have 2 E-switches where there is 1 pictured here. http://seabiscuit68.tripod.com/images/73-74_27-32_color.gif
Your wire colors may vary some, this is for a 74 yr model
jdbronco
Panama City Beach
That's the setup I have and it they both work as they should. I don't have factory wiring but I wired everything to operate the same as factory.
