My feul guage seems to work whenever it wants. What is the most common problem that plagues the EB? Could it be the sender? Bad ground? Bad guage? Thanks for the help.
Frank
Frank
Gummi Bear said:The tank switch could be pooping out, the wire could be abraded somewhere in it's loom (along the drivers frame rail), the sending unit could be screwy (cracked float with a little bit of gas in it or something)or the voltage regulator for the instrument cluster could be on it's way out.
That's pretty much all it could be.
RT said:The snow pulled the wire off a little
BigSwede said:I only have one tank, so the switch issue shouldnt be it. Will check the wiring. Where exactly is the voltage regulator? Is that it on the inside of the passenger side fender? It was disconnected, but when I ran out of gas (haha) and was troubleshooting other items, I plugged it back in. Guage worked for about 3 hours, then was dead again.
Thanks!
RT said:Mine read way full,,,,a few minutes later it read empty..
Heres what I found when I looked under the Bronco:
The snow pulled the wire off a little , I guess the salt water shorted the wire to the frame ,,then when I hit a big enough bump it pulled the snow off the frame and hung by the wire..
Got snow there Frank ??
Gummi Bear said:The voltage regulator for the instrument cluster is small, maybe the size of a piece of Hubba Bubba chewing gum (remember that?) It's behind the cluster, off to the side behind the dash. (~$10, IIRC)
A new vehicle voltage regulator is cheap too, and picking up a spare is never a terrible idea. (~$20-25, IIRC)
Most likely though, it's a cruddy connection somewhere. Go through and clean them up, apply a little di-electric grease, and tighten them up.
BigSwede said:Ok, so what was the box on the passenger side just above the wheel well? It was unhooked, but nothing changed when I hooked it back up.
Will check all the connections before I replace any parts.
