- Apr 19, 2013
- 433
Been spending too much time on my '78 bronco lately, so I need to get back into building the '67. The stock rear end is a small bearing 9 and as it sits, would need a complete rebuild. The plan is for a 351W and a 4r70w. I have a '98 4r70w that I will have rebuilt with the correct parts to mate to the D20. The 351 will be fairly healthy, it will be my wife's bronco and she loves loud and powerful.....whoohooo! Trying to decide between a local engine builder or something like Blueprint, but for the rear end I am going to buy one complete. I have a 2 1/2" lift kit from Wildhorses4x4, and I also have an empty D44 housing I bought from them years ago. Since I have the D44 housing, I plan to have a local shop build the front for me, I haven't checked on any pricing yet but I assume it has to be cheaper than the price for a Currie D44. Their D44 seems to be built to a much higher standard than I will ever need, mine will be open diff and this bronco won't be off-roading much, we use the sidebyside mainly for that now.
I know it will take a while to order a complete rear from Currie, not sure of the backlog right now, but I wanted to ask the collective here if am going down the right path for a complete rear end from Currie. Are there any issues with their rear ends that I need to be aware of that will be different than a stock 9"? Here is what I plan to order from them:
Currie Centurion High-Strenght 9-inch Nocthback Housing
Nodular Iron Gear Case with Daytona Pinion Support
1310 Nodular Iron Pinion Yoke
31 spline axle
5 on 5.5 in. Wheel bolts with 1/2 in. Studs
Eaton Truetrac Posi
4.56 gear ratio
11 inch Drum Brakes
I decided to stick with the 1310 Yoke. I didn't see the need for the 1330 since it won't see any hard wheeling. The 4.56 gears seemed to work best with the 4r70w for around town and highway driveability. I know it would be cheaper to make the small bearing rear work, but I would rather change it all out for new, and to do it correctly the first time, lol. Any advice or criticism would be great.
31 spline axle
Eaton Truetrac Posi
4.56 gear ratio
11 inch Drum Brakes
