Z Bronco
- Mar 17, 2007
- 1,141
Hello,
My Bronco is having some idling issues, it is currently in a shop as I am not able to work on it where I now live. The IAC has been checked and is good (new when I did the EFI conversion), there is perhaps around a 1000 miles since I did the conversion. The problem, if I understood the mechanic correctly, is that the IAC is not getting accurate information from the computer (ground issue?), so it doesn't really know what rpm to idle. I have an A9T that was gone through a few years ago by a member on this board (his work is outstanding), and an RJM harness. The shop's suggestion is another computer.
When the motor is started, it starts at a higher rpm, then kicks down and will surge between 600-800 rpm. Once you start driving, the idle will be a steady 650rpm...for awhile. However, after freeway driving the idle rpm drops to 600rpm, change from D to R, or turn the wheel, at it will drop to 550-500rpm. There are no vacuum leaks.
Thought I would check in with the brain trust on this board.
Thanks in advance,
Z Bronco
Thanks in advance,
Z Bronco
