"Condensation" on hydroboost hoses
Waverous
Aurora, CO
Noticed something odd on the low-pressure hoses of my hydroboost - "condensation". These hoses seem to be seeping hydraulic fluid - there are no leaks or ruptures in the hoses, but there is a small puddle on the garage floor - the Bronco has sat for a couple of months. I think I need to replace the lines - any suggestions for a replacement line?
Wrightracing
I would suggest checking the fittings for leaks. I don't know if they are o-ring fittings, that can leak sometimes.
When I get around to the hydroboost, I plan to have professional lines made for the 2010 Superduty system I have for mine. I just see so many problems with reusable hose fitting, so I want to stay away from where I can. Even my ram assist lines will be custom made professional hydraulic lines. Swivel connections are also part of plan.
David
Wild horse 75
BC
Rubber heater hose is never acceptable for oil. Hopefully you’ve caught this before it’s fully deteriorated internally and sent bits of rubber through your pump PS system.
Waverous
Waverous
Aurora, CO
Yep, that's it! I "thought" I was using PS hose when I grabbed some out of my hose pile. I wasn't paying attention and convinced myself I was using PS hose when I wasn't I screwed up! It's like losing your glasses on top of your head. It's all replaced now and All is better - mea culpa, mea culpa
