Considering new engine- 351 or 347 stroker
mgb0302
So I am considering a new engine. I initially thought that if I was going to go through the time of pulling my 302 to fix/ replace, I might as well go to a 351. However, i realized a 347 may provide me the same benefits without additional mods (i.e accessory bracket adaptors, potential header to tranny clearance issues, etc). I am thinking I will just purchase a short block from summit and put my stock heads on whichever I choose. Don't want to go overboard on price (which is why I am looking at short blocks vs long blocks). Ones I am looking at are (347- https://www.summitracing.com/parts/hpe-sp24/overview/
or 351- https://www.summitracing.com/parts/hpe-sp10/overview/
I would like to replace the engine without needing to worry about additional unexpected mods so here are some questions:
1) Anybody running a 351 and 4r70W with long tube headers and have clearance issues.
2) Anyone by chance ever had both engines at some point? Which did you like better?
General bronco specs are a 2 inch body lift and stock hood. I am not looking for stupid horsepower, just more bottom end torque.
Much thanks
I have had both a stroked 302 (only a 3.25" kit) and a 351W. Both built about the same. Aftermarket heads, as cast. A streetable performance cam. The 330" build was later and got a bit more thrown at it and on paper it was the better engine.
Driving both back to back, the 351 was a better engine. Having built both engines, the 351 is a better foundation. The 351 was less of a hassle as well. The 330 was challenge after challenge, lots more difficulties than the 351 was.
Have a friend who had a mild 351. Got the bug and had a built up 302 and put that in. Now lacks the torque and fun of the 351. Craves more gear to get back the lost torque.
The 302 based strokers do have a place. When you are absolutely critical about packaging (sunbeam tiger is a great example) or weight is critical. Being you will never get a Bronco under 2500# and go racing it, the weight of the 351 isn't going to matter. I call rubbish on the 302 reving better, with a 4R70W behind both of my engines the reved the same or close enough you couldn't tell. How quick an engine responds has more to do with cam and compression.
There are more headaches and surprises in putting a late model 302 engine then doing a 351W.
And if you really want to get into some fun, take the money you were going to toss into the stroker kit for the 347, and put that into a 408 stroker kit.
99% of the 347 stroker kit run great not because they are a stroker, but because they have good heads and decent compression with a well paired cam. Put the head and cam from a good running 347 into a 351 and it will run pretty much the same. And we haven't even gotten into the benefits of running a longer rod in the 351. The rod ratio (length of rod over the stroke) put the rod at less of a side load in the bore. Combustion forces go down the rod and into the crank more and less into the cylinder wall. Better piston dwell at the top of the stroke, less violent acceleration of the piston. In the late 60's Ford put a ton of resources into building the 302 into a 351 and making it a really good package. Bigger bearings, bigger main and head bolts, raising the deck height. Unless you are after light and dainty, the 351 is a much beefier foundation.
BigBlueBronco71
Santa Maria, CA
^^^ This is probably the best answer I have heard and you're going to get, backed up with hard evidence and personal experience, awesome!
Unless you are concerned with about 50lb more up front and having to run a body lift to fit, the 351w is a clear winner
bronconut73
If you run
Headers instead of OEM cast iron manifolds
Aluminum intake instead of OEM cast iron intake
Aluminum water pump instead of OEM cast iron water pump
You should be knocking on the door of a stock 302 set up weight with all of the benefits of a Windsor low end torque and Uber strong bottom end compared to a 302.
Win/Win.
73azbronco
I have a 347, personal choice, i build engines. Unless you are savvy to stroker builds, avoid them
Simplicity dictates a 351 is superior in the cost and benefit argument,
I removed a 351 that has been in there for over 30 years. So they do work great.
I however like the 347 cause there is no "what do i need to mod to make a 351 work " Issues.
sykanr0ng
If you run
Win/Win.
Apples to Oranges.
Put headers on the 302
Put an aluminum intake on the 302
Put an aluminum water pump on the 302
Compare same build to same build.
bronconut73
Apples to Oranges.
If you are pulling out a stock 302 and replacing it with a 351 and do all the mods that I suggested then the weight difference will be negligible. That was the point, ....Weight so it was infact and apple to apple thing ....The apples relate to weight
needabronco
Prescott/Farmington
I think most of you mist the fact that the OP was considering using his stock heads on the 347, which would frankly make the whole package perform mostly like a 302. Strokers need good heads, not stock heads.
So again, my vote is a 351W, especially if you want to stroke it...
I'd look to source an engine locally if possible, a local builder will have a much better warranty and will actually stand behind their work if needed. Mass produced reman engine builders don't have a great reputation for quality, their warranty often has a lot of red tape and in the end isn't worth much. Most require the engine be installed by an ASE certified shop, have a documented break in, and even then they usually only warranty parts NOT labor... A local shop rely's on his reputation and will take care of you. I used to install a lot of reman engines, and we started using junk yard take outs because frankly they ran better and we had better luck with them!
M
mgb0302
Thanks for all of the feedback. After I made the OP, I continued to shop on Summit and realized I could get a basic, 300 HP 351 long block with aluminum heads for cheaper than a 347. That pretty much made up my mind. The only remaining question is wether or not ATK ( the builder of the 351 long block I just mentioned) is a good company with good engines. Any ideas. I am in San Diego county if anyone knows of a local builder that can do the same thing.
5001craig
...I'd look to source an engine locally if possible, a local builder will have a much better warranty and will actually stand behind their work if needed. Mass produced reman engine builders don't have a great reputation for quality, their warranty often has a lot of red tape and in the end isn't worth much. Most require the engine be installed by an ASE certified shop, have a documented break in, and even then they usually only warranty parts NOT labor... A local shop rely's on his reputation and will take care of you. I used to install a lot of reman engines, and we started using junk yard take outs because frankly they ran better and we had better luck with them!
I agree with this. This is what I did. I was ready to pull the trigger on a crate motor and my buddy told me I just had to talk to his engine guy. After talking to him and getting his proposal I ordered an engine from him. I would do the exact same thing again. I had some ignition issues after installing the engine and he helped me a lot to figure out a problem and solution. More details on my engine and engine guy are in my build thread in my sig.
I seem to remember ATK being a member here and posting on a thread like this in the past year or so. I searched for it but couldn't find the thread.
AxlesUp
Collierville TN
ATK does post here from time to time. they build the engines in Dallas TX and you can actually go there and watch yours being built.
I finally decided on the HP11 for my build. hoping this year i get to that point!
https://www.high-performance-engines.com/ford-351w-mid-dress-engine-385hp-p/hp11m.htm
if you have a good local guy that is a great way to go, but all the good guys went out of business around here a long time ago.
mark s
HDS on mission ave in Escondido has a good reputation for their machine work, talk to Dave.
VW Paradise in San Marcos built me dandy 302 years ago that is still running great, I believe the mans name is Joe that runs the machine shop.
With that said, when I spoke to both of them about a 351 for my 73 they couldn't compete with what ATK could offer.
I would have preferred to use either of these builders, but budget won out, and went with the ATK,
I am satisfied with my ATK.
5001craig
A good engine builder can build a 408. My endine guy was a chebby guy but he was good--he researched what it takes to build a ford...stroker.
lX4iXv9tE5bGE3w79JfCQjdHRkQa8bMxdGBV3pNQy2XaozSPXrnyErKvr3ZvfoVUz5cTzv5sE4DUJipPx-JQc4UQ2F3ecfoXd0wOEb4-uSknlYHnaZmhYmOUc3p0tkwqyLxaMy2c-kcTLwWL1OpiG3jipz65X4KRm_k20mguNkRHk0UVg9SD9dh-VnYO_ppdFnAxKqYRay9tj3SuHP4lROY68UIGsHa9rKu0IRlc3oxylVCmn872E3TD058sGhgshPTKHHJ-1zKtj4Tr0XRagNwRnDFiSCx_sqSgfgyodYV0PaxJpC2-gMboyOQZRIy45dNUnQls_ZDBNGtEOnMKex-CcBvcWCbKF-OwssEy5Wx63Oy6rfyM1SreSygSby4DyM8EGzpOq_M3Bas546bCFsquYouE6pmfKD4o7DK9frEu6zPIs0lAwSYl2JzCPxh8TsfjsDKinbLhAxO__tYEC4FdXycLSL6CfWkYdCtBYUY9Y99L0dYU1TegeWvfTZofCRHr__BueKDPsN0HRaPxLEbSpNQgKscxWPUONS-qDA_m269bFBXEqthnKbtNzpOxKHUvztCoG1TJvCJ19M1uYKFegM6FHavILBHBA0fmh4G3mvlgdL2N8Q=w1765-h993-no
bronconut73
My short block is an ATK Windsor.
I have had it in my eb since about '91 or '92.
Perfect and pretty cheap at the time.
