converting a 77 auto column to smooth collar?
blazinchuck
hey guys, i picked up a smooth collar and bearing retainer collar. began removing everything so i could install the new turn signal switch and smooth collar. got everything removed and started comparing bearing collars. the one that came with the smooth collar has a larger bearing ID.
once its sitting in place the steering shaft can move around(sloppy) i even tried swapping the bearing from my 77 to the other bearing collar, but the OD of the 77 bearing was smaller than the OD on the other one...
also tried mating the smooth collar to the 77 bearing collar...but they wont mate up.
so im asking...has anyone converted their '77 auto shift column to a smooth column? i got a nv3550 and want the old auto stuff gone. if anyone has some ideas...please offer up. its my DD so i already put the column back and rewired the old turn switch(didnt want to install new one since i have to go back in it later. thanks,Chuck
Madgyver
Bronco Madman
Cut off existing port hole for shifter, patch with JB Weld, let hardened, smooth down and paint.
thegreatjustino
Red Head Grease Monkey
Stockton, CA
An auto column is worth a lot more than a manual column. Get a cheap manual column and install it in place of the auto column. Sell the auto column for five times what you paid for the manual column.
