I'll throw in the heater control valve to the mix as well.
Intake --> heater control valve --> heater core --> water pump.
The reason behind all this is water pumps don't like to pull hot water. Hot water cavitates very easily. Early ford flatheads had pumps that sucked hot water out of the heads. didn't work very well. So what everone does is set the pump to pull on the coolest water available, that is the cold water coming out of the radiator. That also causes the highest pressure in the engine. the higher the pressure, the higher the boiling point. When solid water is in contact with metal, it cools much better then if there is a steam blanket in the middle.
Probably more then you wanted to know, but I rather type this then go do the next load of laundry...
