coolant flow direction
68rustbucket
San Marcos,TX
Need to know flow direction of coolant to heater core. Assuming the in side comes from intake man. port, and the out side goes to water pump port. Correct? I'm installing propane set-up and need to route coolaant through the regulator.
One more step
Intake, heater control valve, heater, waterpump.
You want the heater control valve before the heater core to keep the pressures down.
Since you will want a constant flow of water through the vaporizer it will get trickier. If you can find the right 3-port heater valve it can work
intake, vaporizer, 3-port, heater, T-fitting (pick up the extra port off the heater valve), water pump.
