Bradsp8
- Mar 5, 2005
- 599
1975 Sport, stock 302, 80k miles.
Seems to have developed fairly quickly, probably over the last 50 miles or last couple short weekend trips. Noticed my overflow bottle is empty and wet spot on the ground where I stop, hit reverse and back into garage.
Coolant leaking and dripping at a pretty fast rate from what looks like the pulley below the water pump. Stops when shut the engine off. I thought it was the lower radiator hose where it attaches to the water pump but I tightened it up and still leaking. I’m guessing the water pump is leaking and dripping down on the pulley below it but I can't stay under there long enough to see where it's coming from as the dripping coolant and fan blowing coolant all over me and my glasses/goggles. I wonder if it's my water pump gone bad or a seal to the water pump that's gone bad.
1. What are the best methods to test and diagnose the issue?
2. How difficult is it to replace a water pump?
3. If I do attempt to replace water pump is it true I might as well do the timing chain while I'm in there?
4. How big a job is it to do timing chain and water pump for someone who has never done either?
