Coolant Leaking!!
commonlaw
Seattle
I am leaking collant from my thermostat housing gasket so I decided to replace it. Sure enough, the old gasket was in bad shape. I replaced the gasket and now it is leaking worse. I am wondering if I did something wrong. I put gasket sealant on both sides of the gasket. Was that incorrect? Anyone have any suggestions or further questions? Thanks
74bronc
there is an instep on either the intake manifold or the thermostat housing that the thermostat has to fit into. It is really easy for you to get it set in place and then have the thermostat shift while you are installing the housing. This wedges the thermostat incorrectly between the housing and manifold, causing a leak. I have seen/had this happen a few times. Take it back apart and see if the thermostat is staying seated in where it needs to.
ehumaui
Do you have the after market chome type thermostat housing or the stock cast iron? I went back to the cast iron when my after market type with the the rubber gasket kept leaking. It has not leaked since I changed it.
commonlaw
commonlaw
Seattle
I have the after-market chrome...i have heard that it may be a problem. I will check the thermostat too. Also, the above link was helpful...thanks. Also, I may not have let it sit for long enough.
Does the sealant serve to ONLY keep the gasket in place for assembly or does it also bond to prevent leakage? It may not have bonded if in fact that is what is supposed to happen. Thanks for the help!
ransil
When using RTV type gasket use it by itself, do not mix RTV with a paper gasket, if you want to keep the gasket in place use weather strip adheasive aka monkey snot, I like the yellow stuff by 3M.
74bob
Broomfield,CO
pitch the chrome one in the trash. I've seen many other people have problems with them leaking. If you pruchase a cast one pay close attention so the thermostat doesn't slip. If it moves and you tighten down you can break one of the ears off. I've done this once.
ca1a73
I changed mine last summer. Had the same problem. I took it apart, resealed it, and tried it again. Everything was fine. The gasket must have moved when i installed it the 1st time.
72_EB
66to77
I couldn't get the stock one to work in the cold when I did mine, so I tried the chrome one with the rubber gasket as a last resort. Been leak free all season. I did prep the rubber gasket with a thin layer of dilectic tune up grease.
mtkawboy
Billings Mt
Use 3M to glue the thermstat in place then 3M the gasket in place and let it set up sitting vertical overnight before installing it so the thermostat dont drop out of place. The I had to retighten mine twice before it completely sealed up. Another fine design from ford like the Dana 30 kingpins
HotWheels
Twilight Zone
I used the "Right Stuff" fixed me right up! I don't know why ford made these housing face perpendicular to the ground.
SeaBiscuit68
Tacoma Wa
There's a product called gasket tack which is made for just this purpose. It's really really handy for vertical gaskets like a waterpump.
wildbill
Old Bronco Guy
:eek: :eek: :eek: Use a good flat surface and some about 400 sand paper and run it over a few times and make sure you have a very good sefface. Use a stock gaskit and some blue rtv and you should be good to go. If a chrome one with out a O ring GET rid of it. Go for a stock one good luck. :p :p :p Bill :cool: %) :p
