HotWheels
Seem my setup hit 200 real fast then stays at 200 on the highway. In city it has been going to 225; and this is w/o the a/c running (need to wire and charge it).
Advanced the timing a bit and it seem to make a little difference; no pinging uphill so I figure I'm ok.
I have the Ron Davis radiator and shroud
Flexalite fix pitched fan
Flowcooler Water Pump
External tranny cooler that runs thru the radiator then to the cooler.
so I'm a bit confused.
Thinking about getting a dyno tune-up then getting the system pressure tested.
