Cooling Problem
schneire
Lindenhurst
I have a friend that just switched from the old style 302 water pump to the reverese flow sepentine system. Since the switch, the motor will not cool at all. He had tried a bigger radiator and multiple thermostats, but everytime he starts the motor the temp guage just climbs and never stops.
Is there a trick to doing this conversion.
broncow72
Village Idiot
Spring,TX.
Did he get the proper fan?
66horse
My first question would be "is he absolutely sure that he has the proper direction water pump"
and the parts guy giving you a part does not equal absolutely sure
74bronc
schneire said:
He is using an electric fan.
unless the fan he put on there is a monster which sucks your pants off when you walk by the grill, this is most likely your problem. You need massive amounts of cfm to keep a SBF cool in a bronco and most electric fans out there are not up to the job. what brand of fan and what cfm? Is it wired right? pusher or puller? there could also be a problem with the waterpump setup, but to me it sounds like the fan.
one way to narrow it down is to try to get on a long road with it and drive at a steady speed about 50+ mph. If the temp keeps climbing, you have a water flow/radiator capacity issue. If the temp stabilizes, you are not pulling enough air through the radiator at lower speeds.
chuck
Ingram, Texas
Did it over heat before he changed the water pump? What all did he change? belt? pulley? what size? Is it a rev. pump or a bi directional?
S
schneire
Lindenhurst
It did not overheat before the pump and pulleys were changed. However, he completely rebuilt the motor when he installed the new pump(rings, bearings, no boring)...
He said he got a serpentinne reverse flow kit from a mustang mail-order house. Not sure the name of it.
