Good Morning, I read the cooling FAQ page. I've already performed all the tips & tricks; smaller pulley on the water pump and we've got everything setup perfect but I still run hot on hot days under load, it's exceeding 220 in normal traffic. That's too high under normal load. I want more of a buffer for when I'm crawling in the hills. I have a 347 stroker, .40 over, '92 gen I fuel injection, professional custom tune from Powertrain Dynamics in Huntington Beach, CA. Ron Davis radiator, Spal fan. Jones Racing serpentine system, Edelbrock high flow pump. The motor is running great but it gets hot and you can notice a drop in power when it heats up. We corrected the hoses and added a second fill point inline on the top hose so we don't have an air bubble problem. I have a recovery tank. We even moved the radiator up a bit so it was centered in the grill opening. Jones has recommended that I remove my T-stat and install a Flow Restrictor but my mechanic says no way. What else can you guys come up with? Cheers.
