Just a reminder that you won't be able to start new posts or reply to existings posts in the Archive forum.
Correct me if I am, but the core support is supposed to be at an angle. Does anybody know aproxiametly what this angle is supposed to be? I know, I should have measured that before I took things apart.:-[
The ends of the front inner fenders are at a angle but the support is straight up and down as far as I know. I'll go check and get back to you. If you have the braces that go from the support to the wheel house that should help you line things up.
It does look as if it tips rearward just a little. I can't get a lower measurement. If you use the braces on the bottom or bolt it to the frame , the top will measure like this...
Go to the front edge of your cowl top panel. There is a lip bent up on the edge. Hang your tape measure on that lip and measure out 34 3/8ths to the plastic rivet hole that holds the small rubber splash shield on to the support. Both sides ! I hope you understand what I'm talking about.
