ft bronc
I have a stock '73 w/ 302. The pcv valve, mounted at the top rear of the pass side valve cover, is currenlty hooked up to the factory air cleaner with what appears to be a factory hose. Everything looks like it came that way.
Is this correct? All my mustangs had the PCV valve connected to full vacuum at the back of the carb spacer plate. Currently, its not sucking up enough of the blow-by sb fords are famous for.
