Why not route the pcv to the air filter or intake? Positive venting is always better then a catch can. Are you running a carb?
Not sure if this is proper or not, but I pulled the PVC from the EFI system and stuck it in the rocker cover. I have done 3 carb'd explorer engines to date this way with no issues.
I look to how to plumb it the cleanest way as to whether I go with the stock Explorer valve (straight up tip) or one from another model (90° elbow) because I like to route hoses and custom bent tubing in different ways in different engine compartments.
Stick with at least a valve from a medium performance engine. The one I got that fit the physical bill but that was obviously wrong from the first start-up was one from a '74 Monarch/Grenada with 302. Ran super lean and did not like that valve.
At the time the solution for me was one from a '72 Corvette w/350. But plenty of Ford engines have the 90 degree fittings and would be just as appropriate.
If you're building a custom engine and don't mind spending $150 for the last PCV valve you'll ever need, there is a custom "tunable" PCV valve offered through the aftermarket that is extremely cool. A couple of members here are using them.
Pretty much overkill for most casual builders with mild engines, but if you experiment with different cams and inductions from mild to wild, it's clearly a winner.
That’s not really a choice because what I think you’re describing are the two separate halves of the PCV system.
The clean air return always goes to the air filter so that clean air gets back into the engine. The valve itself always goes to full manifold vacuum under the butterflies in a common area.
Never from a single intake runner.
You can run a vacuum booster for your brakes or other accessories from a single intake runner, but a PCV system has to run to a common plenum area.
PCV sucks clean air in one side and dirty air into the intake. Picture of your setup?What is this clean air return you speak of? Where does the clean air come from? What am I missing?
Hh
I'm always amused by how many people get this wrong. Even Shelby got it wrong. The black and white picture below is from the 1967 magazine road test. The color pic shows better detail. You can see that the PCV valve is connected to the filtered side of the air cleaner. LH Breather is not ported to anything.That’s not really a choice because what I think you’re describing are the two separate halves of the PCV system.
Totally wrong, and totally outside the design envelope. But sort of effective, and better than a road draft tube.
Don't do this!
No. The two pictures show two different set ups. The one in the valve cover is common for the 351/5.8 size engines, while the one in the back of the intake manifold is common for the 302/5.0.
The second picture would have been correct for the explorer, but you are only seeing one half of the system.
You see the valve in the lower intake and both hoses are full vacuum from ports on the underside of the upper intake. The main (only?) reason for two of them is to give the oil vapors a chance to condense in different parts of the intake manifold so that no one section collects too much liquid oil.
The explorer lower already had one of the best baffle systems in the business, but that doesn’t mean you won’t still condense in the upper. So spreading it out was a good thing.
The little tube fitting in the oil fill neck of the passenger side valve cover gets a simple hose connected between it and the throttlebody when you are still using ford EFI.
Because you no longer have a throttlebody you connect the hose from the valve cover to the filtered section of your existing air filter housing.
Two separate halves of one system. You have full vacuum connected to the PCV valve, and you have fresh filtered air connected to the valve cover.
