Yeah, you need to call them. $1k for a set of springs is not competitive. I'm guessing that the web utility is broken.Duff's (bottom pic) is more than double that of WH (top pic). At first I thought it was an error on Duff's webpage. Is there a significant difference in the springs other than Duff's seems to have a reverse spring eye?
I'm in the process of a frame off and have a set of Tom's 2.5" springs and Rancho rs9000's I bought 10 years ago that I had planned on using. I just watched Monster Mike and his Project Huck episodes and was thinking I might like the 1.5" better since I'm planning on a 1" body lift.....that is until I saw the price!While Toms doesn’t have a 1.5” they do have a 2.5” that is even cheaper at $400 with bushings and u bolts. The differences probably come down to being made in the USA or overseas. Also the quality of the steel I’m sure makes a difference.
I think that's the difference. Duff uses USA-made Deavers and most of the rest are made overseas.While Toms doesn’t have a 1.5” they do have a 2.5” that is even cheaper at $400 with bushings and u bolts. The differences probably come down to being made in the USA or overseas. Also the quality of the steel I’m sure makes a difference.
The last cheap set I got from Tom's was made in India with a 10mm metric center pin. They fit fine, and they worked fine.I think the cost delta is due to USA-made vs. overseas-made.
Todd Z.
Yes, I saw the same when I visited there back in 2010.The last cheap set I got from Tom's was made in India with a 10mm metric center pin. They fit fine, and they worked fine.
I assume that they were made in India because they had a giant painted stencil that said: "Made in India."
That's good to know! I knew they used to be but didn't know if they still were or not.WH Springs are made in the USA, right here in CA.
About $260, I added an adjustable track bar to the quote in case you needed it. Without it on there, it did not not change the cost more than a few dollars. I quoted this to 27703 since I do not know your exact shipping address.@1969miller
Any idea what the 1.5" System 3 freight would be to 27712 in Durham, NC? The WH site shows shipping can't be calculated .
Thanks for thatAbout $260, I added an adjustable track bar to the quote in case you needed it. Without it on there, it did not not change the cost more than a few dollars. I quoted this to 27703 since I do not know your exact shipping address.
