I have a 1977 bronco with the 302 ford. When I bought the bronco it had a fitech with a fuel comand center and after numerous issues, i finally got rid of the fitech, the fuel command center and when back to a carburator.Since it had a 4 barrel intake ( an edlebrock intake) for the fitech, i went back with a edlebrock 4 barrel performer carb. Other than that the bronco is original. when I had the fitech woes, i put new electronic ignition module, new coil, new switch, new battery, pretty much all new electric componentry. I have not tuned it up, but it does not have stock distributor cap or rotor or wires nor plugs. The bronco only has 57000 original miles. The bronco was bought for my daughter.
After we put the carb and got it set and got it running it ran great. It took a little bit to get electric choke right, but it was running good. But then a couple of times as I drove it it acted like the power was cut to it then picked back up, did they several times and then ran fine. I drove several times over the next few days and it did not do it, but then did it again. It never died but just felt like it was losing power, then picked back up, did that several times and then ran fine
So my daughter is driving it tonight and of course I am out of time, and it does the same thing to her and then quits. She can't get it started again. My neighbor and my wife go to get it, and they can't get it started after trying several times, but my neighbor shifts it to neutral and trys to start it and it doesn't start at first but after a few tries starts, He turns it off and then moves it to park and it starts. So my wife gets in it to drive it home and it starts the losing power then picks back up on her as she starts up a hill heading home. It never dies just acts like it but then runs fine the rest of the way home.
last week when i was home, i pulled off distributor cap and there was a build up of corrision on the inside of the contacts of cap, the wires looked old and the rotor looke worn so I bought new cap, rotor plugs and wires to change out this week end, but I don't think the symptoms i have seen would have anything to do with those things. I did notice the star wheel at the bottom of the distributor that rotates with the electric pick up was rusty. i planned to sand the contacts when I tuned it up.
So the question is, any idea based on what i told you, what could be the issue with it that I need to fix to keep it from stranding my daughter on the side of the road as it did tonight. What would cause this lost of power, then pick up, lose power, pick back up, do this 3 or 4 times in a few seconds and then run fine or quit and then not start- The coughing and quiting seem to somehow be related. Electronic ignition pick up? Neutral safety switch? Distributor? Any suggestions and how I can check it would be great or what to fix on it. thanks for any suggestion
