When does your ASE for Electrical expire? How many Ford electrical courses have you passed? How many vehicles have you totally rewired?
The battery supplies the vehicle power; the alt recharges the battery continuously while the engine is running, so it APPEARS to supply those loads. But if you have a 60A alt, and you apply 100A of load, that current comes from the BATTERY. The alt still only puts out 60A, so there's NO "additional" load on the charging system or its wiring. That "additional" load only goes from the batt, thru the new wiring & back to the batt - NOT on the truck's original wiring.
And if you connect a new 100A load at the alternator, the current will come thru the charging wire (thru the dash) from the BATTERY, which could set the dash on fire. I've had to repair entire wiring harnesses from people doing things like you're recommending.
Please stop giving electrical advice. If you're a top transmission rebuilder, post away because I know squat about them.
