Crank Pulleys on Bronco 302's...
bulletpruf
San Antonio, TX
Fellas -
I have two 1969 Bronco engines here. Both appear to be 1969 Bronco 302's given the heads (both castings have "302 2V" that's visible when you pull the valve covers), both are 2bbl carburetors, etc. However, one has a 4 row crank pulley and the other has a 3 row crank pulley.
I'm guessing these aren't original because a 1969 Bronco would only need at most a 2 row crank pulley, because with no A/C available and no P/S available, you just need a belt for the alternator and one for the smog pump, right?
Ford wouldn't put a 3 row or 4 row crank pulley on an engine that only needed two belts, right?
I can't find numbers on the 3 row pulley but it came off a C9OE 6316 D2 balancer, which is correct for a 1969 302. The 4 row pulley is still on the other engine, but it's going to have to come off at some point soon.
Thanks,
Scott
Your logic is correct. Never seen a 3 or a 4 row pulley on a Bronco. Maybe there were some 3-grooves on later models, maybe '76 or '77? But a '69 would have had more likely just the one. Not sure if '69 was an air pump year or not. And sometimes Ford ran the pump off of a second groove in the alternator pulley rather than an extra one on the crank.
My 400 has a separate groove, but most of the 302's I've seen ran a short belt from the alternator to the air pump. At least I think I remember that being the case.
So yeah, kind'a weird.
Any other clues? Such as dipstick location and oil pan style? Any emissions decals on the valve cover? Not sure if a '69 truck would have had one, but very possible.
A likely scenario too is that the dealer or other added aftermarket A/C and used whatever pulley they could find that had the right offset.
blubuckaroo
Grease Monkey
Ridgefield WA
Even the Broncos with power steering only had two crank pully grooves.
The air pump on my '77 was driven with a little belt from the alternator.
I installed a three groove pully for the A/C, but that longer pully makes it tough to fit in a decent fan.
bulletpruf
bulletpruf
San Antonio, TX
Fellas - Many thanks for the input. I'll check oil pans and dipsticks tonight. Neither engine has emissions decals on the valve covers.
EDIT: If anyone wants to trade an original single groove crank pulley for a 3 or 4 groove, let me know.
SHX669
I don't remember what year Ford went to dual groove pulleys but we were all very happy when they did. That made Two belts driving the water pump vs one which is helpful if you break or throw one belt - something to consider.
I swapped mine for duals all the way round when I went to a large case, high output alternator. Stopped the belt squealing, and also got me out of Death Valley (literally) when one belt broke.
bulletpruf
bulletpruf
San Antonio, TX
Double checked and both pans are correct Bronco oil pans with push in type dipstick on passenger side.
Attached a few pictures of the 3 row pulley. No numbers cast or stamped that I can find.
WheelHorse
My '77 has a heavy three grove pulley. I often wondered how much hp I'd free up with a lightweight aluminum crank pulley.
jckkys
This is a weird subject and has been since the '60s. My '68 had the air pump with a 2 groove cast iron crank pulley. I didn't know how the air pump was powered as some PO tossed the belt. My '77, I bought new, had no air pump from the factory, it did have 2 groove pulleys for the crank and water pump. One belt was longer to turn the alternator and another turned the power steering pump. I changed it like Paul did with a 2 groove pulley on the G1 large case alternator, and one long belt for the all the pulleys plus the power steering pump. 2 belts on the alternator ended the squeal upon start up. That's one of the big selling points for serpentine belts that I never bought into.
bulletpruf
bulletpruf
San Antonio, TX
I put an ad in the Wanted section here for a single row crank pulley for a 302. Posting here too just in case anyone has one.
jamesroney
Fremont, CA
I read this thread, and I also saw your wanted post...but I can’t make heads or tails out of what you are actually looking for.
There’s a ton of confusion on the early crank pulley, and it turns out that the list on MustangTek is missing the Bronco one.
I have the pulley that you need. It is the C9TE-6A312-C pulley. It is often listed as a 351 pulley, (but you couldn’t get a 351 in a 69 Ford Truck.) now that you know that...it should be easy to find.
I’ll sell mine for $40 plus the ride, because that’s what I paid. But you can get them cheaper on EBay. You just need to search on that number.
bulletpruf
bulletpruf
San Antonio, TX
You're right -- there were several on eBay. I bought a nice looking one for a reasonable price.
Thanks for the details. I appreciate it.
Scott
bulletpruf
bulletpruf
San Antonio, TX
See attached for another pic of what the pulley situation looked like on the truck.
Anyway, I ordered up one of the pulleys off eBay that @jamesroney recommended and I'm all set! Got things back together and pulleys line up just like they should.
Looks a lot better and sure was nice to get rid of that monster crank pulley, too.
As was mentioned it could have been installed by an aftermarket A/C installer even through the dealer at the time of purchase. The water pump still has the single groove pulley and no power steering, so maybe instead of just a two-groover, the installer found a suitable three-groover instead.
Any other clues that you might at one point had A/C installed? Extra holes or brackets under the dash? Large holes in the body/floorpans for drain hoses? Extra firewall action somewhere?
Otherwise it may just have been a qiuckie replacement when a stock one could not be found.
No matter now though, as it sounds like you've got yourself a single-groover working for you and you're good to go.
bulletpruf
bulletpruf
San Antonio, TX
Paul -
I have found no evidence at all of an AC install.
I thought maybe the PO had swapped another motor in at some point, but I don't think so. The harmonic balancer is the right one, the block is a '69 block, intake seems original, etc. Still possible, but not very likely.
I'm thinking it was something swapped in to replace one that was somehow damaged or broken.
Scott
Sounds like the most likely scenario. Damaged while working on it, or even lost in the garage when it was a long-term project. Or like in my case, loaned to a friend "temporarily" (unless it works of course!) and a new one needing to be sourced.
"Lots of stories in the big city."
jckkys
Something else you may want to be cognizant of is the lip/no lip issue. The '66-'68s had a "lipped" pulley. The lip on the crank pulley protruded into a relief in the front of the damper. In '69 the pulley had a larger center hole and a lip in the damper that fit into the center hole in the pulley. The '69 Mustang 351s used the same damper and crank pulley as the 302s. After that both the 302s and 351s went with the 4 bolt pulleys on everything but EBs where the 302s kept the 3 bolt pulley through '77.
sprdv1
REBEL
concur w/the questioning and heads up
