Has anyone ever installed an aftermarket crank trigger on a 351W with the standard water pump and front dress.
I am building a new 408W. Using a Holley Terminator X ECU. Holley EFI Hi Ram intake. Need a cam sync signal and ignition signal. There is not a ton of room under the Hi Ram intake for a dizzy. I also have a cross brace between my coil over shock hoops that add to the fun. Obvious method is to use a Holley dual sync dizzy. Needs a special one low profile. One thing is with this I will need to use an ignition box with using the dizzy for spark application with a conventional coil. Not sure I want to use an ignition box (MSD). Another thing to wire in and maybe fail. I can add a cap on the dizzy and then use LS style coils with coil on plug application. Just thinking about doing something different not spending a ton. Even though this method probably is not the cheapest.
Thinking about a MSD cam sync dizzy to run the oil pump and the cam signal. Then I need a crank signal. Most Ford crank triggers are passenger side but standard water pump is there. I also think that some Explorers use a crank signal and also cam sync dizzy. Then I will need to change all my front drives and stuff to Explorer stuff. Internal balance engine also so need neutral balancer.
Mostly maybe trying to do something different so just wandering if anyone else has.
