rastiss
Bucky was giving me fits. Last summer I had it act up 3 or 4 times when it was really hot outside. Edelbrock Carb 302. Previous owner put an inline electric fuel pump on it. Over the winter I replaced the rear tank with a 23 gal from BC. New tank was blown out really well with air before installation. New filter. Running down the road it randomly starts cutting out and slowing down and usually ends up dying. Fuel pump still runs but no fuel in the clear fuel filter. After sitting a couple of minutes, the filter fills, it starts right up, go a few miles and it does it again. Took 2 hrs to drive 50 miles to Lawton. I replaced the electric fuel pump, didn't change anything. I tried running a fuel hose outside the frame and routed it different way thinking it must be vapor lock. Tried running with the fuel cap loose. When it cools off its fine. My next thing to try I guess is a phenolic carb spacer. The only different from last year besides the fuel tank is the grille I made. Since it isn't overheating its hard to believe that would do it but maybe its changed airflow? Didn't seem to make any difference running with the wind or against it....
