blazinchuck
- Jul 14, 2005
- 3,319
When I installed the 306 a while back, I put a lil warmer stat in(180°) thinking this would be best...using a "fail safe". Well as I learned...you can't tell its bad unless...you just never get to temp. this was the case-it failed and was wide open
So fast forward some... just before this past novrun... I replaced it with stock style 185°… since then, been fighting the same problem. engine never would get to temp! always bout 140 or 150...and the heater never put out like it should...using a mojave heater.
Today I decided to replace it AGAIN! Welp...surprise! it some how got cocked!! Causing it to not reach temps. Installed a new 190° and after 3 attempts...truck got to 185,187,183 after 30 min cool downs. Each time temp was around 150 or so for each start up. heres a pic...and yes, it was installed right. i remember the 1st night i installed it...it got to temp within 10mins idling in the driveway in 40 degree weather. since then...its never reached temp-even had to run cardboard in front of rad to bring temp up at our novrun@ure.
heres a pic
heres a pic
