Crimped Rubber Brake Hose
jeremywatco
San Diego, CA
Before I go and grab my cutoff wheel and grind it away.... is there a better way to remove a crimped on rubber brake hose? The hose from the front frame to axle is rubber and crimped onto both fittings. Hose is already cut in half.. just need to remove the fittings so I can proceed.
THanks, Jeremy
Diagonal side cutters "Dikes" work just fine.
Since the hose is already cut, the fittings don't get reused, it is all garbage at this point. Just save the attaching hardware.
Rustytruck
If your lifted you can use 78/79 Bronco lines they are longer. Keep that in mind if your out in the middle of nowhere needing repair.
