Custom Heater and Rad Hoses???
carter2772
Camano Island, Wa
I am wondering if there is a place anyone knows of where a guy could get custom made heater and or radiator hoses... Basically needing hoses with a certain degree bend in it... Any one?
I have walked into aparts store, talked to the counter help, then was led to the wall of hoses. Picked over until I found a hose tha had a section the right shape.
The other version is glorified muffler tubing bent and shaped as needed and use short rubber or silicone sections for flex.joints.
But actual custom molded hoses, I don't know anyplace. I would also be scared of the cost.
pierr
Gordon,GA
Wild guess;D...you're having trouble getting a new hose on a new heater core & it's a PITA cuz all the aftermarket heater core hose ends are way too long & interfere w/ the inner fender%) . IF this is the issue you're having...ferget finding that "majical" hose & just hacksaw it off about 1.5" out from the firewall. Problem solved! If you're chasing some other issue..do as Bowsher said & get permission to go behind the parts counter & search till you find a combo that works.Pierr.
marty
massapequa, n.y.
worse case go you your local marine supply they will have numerous types of hose including wire reinforced. heck of a lot cheaper than making custom hoses. i myself ran into the issue when i did the efi swap and used a 4.0 explorer radiator and had the issue of 2 different size hose diameters and had to make a reducer to fit. being i am in the marine business i went to my local marine heat exchanger/oil cooler manufacturer and had him just put a barb on the end of a copper reducer so the hoses would not slip off.
carter2772
carter2772
Camano Island, Wa
I wonder how the hoses that are already out there at the part stores are made? They must start as some sort of straight hose or on a roll, then put over a cast or into a cast, then heated up..?? Hmmmmm....
