Custom Tire Carrier/Bumper
jperry1290
I am looking at fabricating my own rear tire carrier/bumper. It appear that the trailer spindle design is the most widely used hinge on the market. However, I am wary of the spindle design due to the shearing problems. Can anyone advise what other hinges they have used, how they held up, and where to buy them?
Don't have any real alternatives for you, but am curious what shear issue you're concerned with? Is it just that it's mounted/welded to a single layer of metal?
deltarat
Drew,Ms
I have a 4x4" bumper and the spindle is welded on the top, a plate in the center and at the bottom. The other end is supported with a 1" hard pin that is welded all the way through the bumper. I believe the bumper would tear off before the tire carrier broke.
Steve83
There shouldn't be any "shearing". Most of the loads are applied as torque. Since a trailer spindle gets a LOT more load & impact than a tire carrier, you don't have to worry about the spindle or hub breaking (unless you modify them). All you have to do is attach them at least as well as they're attached to a trailer.
But I'd probably use an eB hub & spindle, just in case you DESPERATELY needed some spares to get home. Trailer parts won't get you out of the woods if the truck breaks.
ransil
I have seen a few of them shear or what ever you call the failure, there are pics out there.
I have seen 2 rod ends used, I have them on mine no failures yet but I haven't back into a tree yet.
ManTruck
I currently have a homebuilt and have no problems with my spindle I used and been hauling 33's and 35's on it for a while. With that said I have a new bumper I have picked up and just bought this spindle and really like the design and thoughts behind it. I have yet to work on it but am happy with what I see. They also have a new hindge that looks pretty durable.
stretch
Montgomery, TX
I have a pic somewhere on my computor that is a Dana 44 spindle cut down and the guy used a Warn locking hub on it. I thought it was a very interesting design and bullet proof if done correctly.
68rockcrawler
Here is my tire carrier. It just uses greasable bushings at the bottom and hooks in at the top using hitch pins in to bushings. It only works if you have the BC Broncos quarter guards to weld the upper mounts to so this design is not for everyone.
