The valve on an old bronco motor I am trying to revive is stuck in the open position. In fact when I cranked the motor it bent the push-rod. Could it be a bad valve guide? Thanks, BI
I'd assume it is just gummed up. When I first bought my truck it had several sticky valves. So I poured a quart of tranny fluid in the carb while reving the mototr to keep it from stalling. WARNING........ If you do this, be prepared to smoke out the entire neighborhood. It did clear the issue but, as stated, created a HUGE smoke cloud.
If its been setting a while with the valve open they will rust enough to stick. Would take 2 weeks for a new 351W to do it in S Fla at the dealership in 78. I predict that the valve will also be bent slightly unless you are incredably lucky. Marvel Mystery oil works really good before they bend and also frees up stuck rings. Pour it in the cylinder & let it set. After requires quite a bit more work. Would have been cheaper to ask first
