Cylinder Head Advice
BrettKoenecke
Hi all, I've owned a 73 Ranger with automatic and stock 302 since, wow, 2014 I guess. My neighbor is in his 70's, loves to tinker, and thinks I have a need for a valve job. OK fine I have no problem with that and we don't need to rediagnose that here. What I can't find is a shop in my small remote rural town who's much help on this deal. Seems I can have a valve job or I can just buy remanufactured heads for it. I don't have a real good sense of which way to proceed and could use advice in this regard if you have any to give.
Its a good running outfit and has been fairly easy to keep operating if you count the rebuilt transmission, the new water pump and timing chain and etc. My problem is that every time I find someone to help me with it, he or she ages up and out and there's no one coming back in who seems to want to work on it.
I hear you on the aging out. We've lost tons of places here and we're in the middle of "the big city" so to speak!
We used to have several places that did heads on an exchange basis that were actually really reasonably priced. A couple hundred bucks and you have basically new heads. Cost more than that by about double to get a simple plain ordinary valve job.
Wish I'd known about those (or maybe they weren't around here then) when I had my own valve job on the '71 back in about '80 or so.
But some heads are actually better now too, so there's a good argument for swapping. Even cast-iron heads are pretty high performance these days.
What kind of service are you looking at? An exchange place with regular stock type heads? Or buying new from some source like Summit or a speed shop supplier?
If an exchange spot, will they give you E7 ('87 or newer) heads in place of your '73 heads? Maybe even GT-40 and GT-40P heads? Those are all factory offerings, but from later more efficient designs.
I'd have zero problems doing an exchange, even for like '73 cylinder heads. Just that when you go to this trouble it's nice to have certain upgrades.
Others will have good advice on that, and on whether some heads are worth the changes you'd need to make along with them. Such as perhaps new rocker arms (might need them anyway) or new exhaust manifolds if you went with something like a GT-40P head.
Good luck.
jamesroney
Fremont, CA
Good luck.
Good advice from Paul.
One thing to consider is the availability of cores. In the "good old days..." when high quality cores were readily available, the probability of getting a good head back from an exchange was very high. But now, cores are drying up, and the percentage of junk heads is increasing.
So if you are going to buy exchange heads, make sure it is from a reputable source that will make good on the warranty. American Cylinder Head in Oakland is still doing good work. But it's not their fault if they get cracked or junk cores... It's getting to be like rebuilt carburetors in the 90's. Eventually, every carburetor that got rebuilt had internal leaks, and those junk cores just kept going round and round. (Eventually Edelbrock and Holley sold new ones that always worked...)
So keep that in mind before your surrender your cores. Or insist that you get your exact same cores back. Nothing worse than an internal crack in the heat riser port that opens at temperature, and creates a misfire. Then re-seals when cold. Theres' nothing wrong with hoarding your own original cores!
Also, you want to make sure that you get your exact same casting numbers back on exchange...especially if you are running thermactor. Lots of SBF ford heads interchange...but they aren't exactly the same. ( It's really annoying when the bolt for a bracket is missing the hole...)
As Paul says, there are many better heads on the market today, and I would never put more than about $50 into a set of stock heads. The Mustang 5.0 and Explorer GT40 heads are 1000% better, even used ones.
B
BrettKoenecke
You guys are incredibly helpful. Thank you. I don't have a problem putting some money into new heads but I have no clue what to get.
I do have headers already, which went on in 2014.
Timmy390
Conway, AR
OK so not going into WHY your neighbor is in his 70's thinks you need a valve job.........I'll just provide some in my 50's advice :)
IF you go with new heads you MUST get the chamber size correct or you will lose more than just money. The 70's smog heads were 58cc. The engine was low compression at about 8.5 If you want to go with a better flowing cast iron head, the GT40P's are 59cc. The E7's are 61cc GT40's are 65cc
Stock Bronco manifolds will work on the GT40P's with some grinding but the headers you have will not. The spark plug angle is the issue. The headers should fit up fine with the E7's Either head can be had from any scrap yard or pull a part lot. I got mine there. I disassembled them, Cleaned everything up including removing all carbon, replaced the valve seals, lapped the valves and run them. Then I upgraded my cam and had to install new springs but that's another road to travel.
My point is....you can pull a set of heads, clean them up, renew a few things and install them for cheap. I got my GT40P's for $70 each as I recall.
Tim
SteveL
Huge chevy guy
Hawthorne ca
Do the 96 explorer heads have the correct spark plug angle for the old school eb long tube headers?
Timmy390
Conway, AR
I think the switch to GT40P's was a mid year change in 1996. Verify what your getting....my understanding is the GT40's fit the old school headers but I've not done it myself.
Tim
If the engine is complete, look at the EGR. If there is a big supply tube coming off the passenger side exhaust manifold those are P-heads. If the EGR does not have an external supply, the supply is internal to the intake manifold pulling off the exhaust crossover passage, that is the non-P version of the GT40 head.
'96 should be non-P heads. The running change was a year later, about a quarter of the way through the year.
lars
Been here awhile
NorCal flatlands
I'm shooting from the hip here a bit, so don't hate me if I don't get this 100% accurate...
I can say with confidence that the gt-40p heads were 1996-1/2 and later, exclusive to the Explorer 5.0. They may be one of the best-breathing factory cast iron heads, they are the only ones that cause problems due to the spark plug placement and subsequent interference with a lot of headers. All others except possibly for some race heads will accept standard headers and have spark plug location that doesn't cause clearance problems.
Ford made a "GT-40" head as an aftermarket high performance cast iron head back in the late 80's(?) early 90's that eventually found its way onto the early Explorer 5.0 engines. Good head, doesn't give up much to the "p" version and everything (all headers ever made) fits. But even the head found on stock Mustang 5.0 engines from 88 (or earlier) to at least 1993, the "E7", was a lot better than the stock Bronco head. That head was used on a bunch of 5.0 equipped vehicles besides the Mustangs, and is probably still relatively easy to find in junkyards. I can't imagine paying more than 50 bucks for a junkyard set. Bummer that it's so difficult to find a shop to rebuild some. Used to be the local NAPA in my town would do it, and they did a good job.
Timmy390
Conway, AR
Super helpful...what kind of donor vehicle would have the E7 heads on it?
Best bet is any 302 or 351w truck/van from like 87 to 96. My 96 E350 van with 351w had E7 heads.
Gt40P's are the best stock iron head Ford produced but the plug angle sucks. I've read the explorer exhaust manifolds work well on the Bronco and of course fit the P heads perfectly. I'm told they flow well too.
Tim
Timmy390
Conway, AR
Biggest cam you can run with stock GT40P heads. Anything bigger than below you will need to upgrade springs.......
Intake at 1.6 rocker ratio .422" lift 256 duration
Exhaust at 1.6 rocker ratio .448" lift 266 duration
1.7 rockers is .449 intake and .476 Exhaust
904Bronco
San Martin, CA
Couple of things to add...
97 was the change over to P-heads - 4 slashes on P end castings vs. 3 slashes on the end castings for the GT40's
Not to say that on an early 97 you can find the GT40 heads, Broncobowsher's above comment is correct on the EGR set up. And you can check the build date on the door as well, it the tag is still there. (it would have a late 96 date)
I don't like the 96 exhaust manifolds, sort of a tubular design, and restrictive. I would run the Bronco stock manifolds or headers on the GT40 heads. 97 and up cast iron manifolds for the P-heads flow better. You can still buy them via Dorman (Chinese product) on Rock auto.
Supply - I find a lot of the 96 Explorers in wreaking yards have the GT40 heads/upper/lower plenums already harvested for earlier engines. Remember your dealing with a 26 y/o product now, so finding one can be a challenge. (Especially here in CA it seems, stock gets rotated out after a few months)(Cash for clunkers in 2009 did us a disservice as well)
For simple bolt on you would be best served by E7 castings (87-93 Mustang comes to mind) or the GT40 heads from an Explorer.
Also these later heads have valve springs setup for higher pressures of the roller cams. Rocker arm design is different and so is pushrod length.
MonsterBIlly
My question to the other guys posting on here would be why not go with a set of aftermarket heads. On the more spendy side you could go with a set of AFR or Trick Flow heads. On the lower end you could install a set of blueprint heads or procomp. Either of the 4 will give you significantly more HP and the price diff would not be that much more. you most likely could use your existing exhaust manifolds or headers depending on which ones you have. I did not read all the write ups above.
https://www.summitracing.com/parts/...dUtXAFma00V4JS3IKsr4gPcw0ZnrM3JIaAi-HEALw_wcB
https://www.summitracing.com/parts/afr-1351/make/ford
https://www.summitracing.com/parts/mll-hp9009/make/ford
https://www.ebay.com/itm/3720381040...d=link&campid=5335857059&toolid=20001&mkevt=1
I guess it does appear that the blueprint heads have increased in price. you can have them milled a little of you need to increase compression as well. I just cant see with as much work as it is and the difference in price to not go with a better head. But, This is just opinion
Timmy390
Conway, AR
IMO if only swapping heads on a stock or slightly warmed over engine going aftermarket is not cost effective. You will not gain anything over castiron and in some cases lose due to some chamber sizes. Just money wasted
The OP isn't changing cam or intake or carb. He's just looking for the cure to needing a valve job. If he were building a high RPM performance engine aftermarket is a good choice.
Tim
