matt w
- Jun 12, 2007
- 2,798
My D-20, Twin Stick, Tera Low front stick has developed a new problem.
When both the front and rear axles are engaged in low, under load I.E. Hill climbs, the front will slip and eventually pop out of gear.
Needless to say this is a dangerous development.
Yesterday I pulled the detent spring which looked a little bent and I noticed the stock retaining bolt had been replaced by someone other than I .
I then stretched the spring a bit & added a shim between the spring and retaining bolt as an attempt to put more pressure on a possibly worn out spring,
I will now order a new spring since this did not fix the problem.
Is there any other advice or other possible problem that you have experienced that would help me eliminate this issue?
Thanks Guys!
Matt W.
Thanks Guys!
Matt W.
