70_Steve
Old Guy
- Dec 13, 2002
- 8,317
Well, that large spacer will bottom, against the gear. If you look at the pic, you see the front output shaft with the large gear-looking splined end, where the sliding gear goes. Going forward from there on your j-shift (not in this t-shift pic), you've got a gear, a (large) spacer, the front bearing, the small spacer, then the yoke. When you tighten up the yoke, it will be tightening up against that large gear-looking splined end, but through the gear, spacer, bearing and small spacer. So, with 150 ft/lb torque on the yoke nut, even if you didn't press the front bearing on far enough, by the time you tighten up the yoke nut, it will be in place!!!So your saying the small spacer is only for the yoke and the bearing should press fit tight to the gear with the large spacer in betwee, got it. Good to know as I was going to drive the bearing in until the spacer bottomed, that would have sucked...I think. thanks again.
Because of that, I usually install the yoke and torque that nut before messing with the shims.
