- Aug 22, 2005
- 14,493
What would cause a d20 shift rod to stick. I mean stick like stuck! I have this 20 left over from my dead 66 half cab and thought I would go thru it to get it ready for my dads truck. Doing a 435 /20 to it. I got it on the table and one of the rods was stuck. So I started to take it all apart. Got all the springs and detent balls out of it, center cluster gear, rear output. I just have the two gears on the end to come out. the front drive shifter rod wont move. I cant get the gear off the shift fork because I cant get at the set screw in the fork because the gear is in the way. I think if I bend up an allen wrench I can get to it. After I get this all apart are there any tricks to getting the shift rod out? it's not rusted up, the case had oil in it. Slide hammed comes out next?
