i'm not sure what year the axles are,whats the easiest way to find out? i bought them from a guy several years ago,i'm thinking they were late 70's units..the truck is a original two wheel drive f150 that we converted to a straight axle setup with leaf springs,etc about 15" lift and all..i just never drive it anymore and was thinking of putting the drivetrain in the bronco since that big ole truck will be hard to sell nowdays..keeping them std width i think would have the tires sticking wayyy to far out for me to drive it on the streets
my guess is the PO did an SAS and used the early axles as most of them do. if the front axle is a straight axle then it is an early axle because ford stopped using the straight D44 axle in 79, 5 lug or 8 lug. as for the rear axle i think you can count the rear dif cover bolts and tell which rear axle you have a d60 or 10.25.
