Bronco73
WAH is nice but i may never really need something that extreme plus the cost is a bit steap for my needs. i may just have to hold onto one of these axles and haul it with me to FL. ;D
second option is to pull the axle tube from the center housing and shorten and then machine it for the new seal which be a problem in itself. How does one chuck up and axle tune with a C on one end and the <> still attached to the axle? .
Use a WAH. Well worth the money once you have one!
I'd bet your machine shop is not certified on much.LOL..'booty fab' eh? Heck..I guess a lot of what we do in our 5500 sf machine shop would qualify as booty fab then. Good thing our welders are 'booty fab' certified too.;D Having narrowed so many all the different ways ya can..our booty fab approach has turned out to work the best for us in terms of time requierd for results achieved. We use the same technique for narrowing D60 rears too..gasp!
I'm not knocking the removal of the castings and cutting down the tube end as a good way to go, however..because it is.
I had one other question. Will a 110 lincoln welder be good enough to plug weld the axle tube?
Yes, that is the article I was talking about.heres a good link on narrowing the D44 axle. http://www.therangerstation.com/tech_library/narrowing_a_ford_dana44.htm
time to start making some dowels for the ball joints so i can check the camber/caster settings. ;D
Please post a good source backing your information.A WAH is nice for added flex, I have one myself, but it is basically an axle tube cut in two with a sleeve rosette welded to one side and a hub attached to the outside to keep the two tubes from puling apart while allowing twist. If you just need to narrow an axle and don't need the added flex a sleeve inside the tube rosette welded on both sides and butt welded is much cheaper and just as strong if not stronger than the WAH. Plus I would argue that this joint is stronger than where the tube attaches to the cast center section.
Great idea! (I like this guy!)I'd suggest a 73-77 1/2 ton axle housing, good core should cost under $100.
bmc69, be careful who you call out. I know a little on the Dana axles.
