d44 narrowing , cast wedges?
Bronco73
Cape Coral, FL
i'm not sure what year the axles are,whats the easiest way to find out? i bought them from a guy several years ago,i'm thinking they were late 70's units..the truck is a original two wheel drive f150 that we converted to a straight axle setup with leaf springs,etc about 15" lift and all..i just never drive it anymore and was thinking of putting the drivetrain in the bronco since that big ole truck will be hard to sell nowdays..keeping them std width i think would have the tires sticking wayyy to far out for me to drive it on the streets
my guess is the PO did an SAS and used the early axles as most of them do. if the front axle is a straight axle then it is an early axle because ford stopped using the straight D44 axle in 79, 5 lug or 8 lug. as for the rear axle i think you can count the rear dif cover bolts and tell which rear axle you have a d60 or 10.25.
ricky
beaumon,texas 77706
it's an early axle,just not sure what year,i'll count the bolts when i get home tomorrow on the rear..how do you install the wedges,etc to convert the spring flanged axle to one that can be used with the radius arms? also ,anyone know who makes the tubular radius arms? i'm thinkin i better start my own thread..did not mean to hijack this one
scsm76
Shaver Lake, CA
You might look at Cage radius arms they sell a mount that eliminates the wedges altogether to use with there arms.
Also take a look at Crawln68's bronco (long build thread but lots of good info) he originally had a 78-79 8-lug D44 and has now upgraded to a D60. He ran them full width and with the hummer wheels and 39.5 x 13.5 Iroks, his tires stick out about the same as mine stock width. I think his overall track width was ~83".
Here is a couple pictures of his bronco, the blue one is his mine is the orange one in front on the trailer.
bigbri69
tomsriver
any body have pic of a 78/79 hp 44 uncut bolted under a eb.how much springbow do you get and can the coilspring pop out easy like that?
Tito
CB Fire Starter
Bakersfield, CA
Here is mine. They wont pop out. The last pic is on its first trail run getting things settled in.
Phoenix0783
The springs are secured at both ends, they can't just pop out. They would have to somehow rotate out of the tabs that hold them in place.
