First time tearing one of these down - Got to the point where I want to pull the pinion, but the oil slinger right behind the pinion gear hits the case under/behind the driver's side axle seal area.
I can probably get it off by trashing the slinger, but if it is pressed in between the gear and the bearing, how do you get it back in?
Probably missing something here.
