D44 upper ball joint socket?
eBronc
Austin, Texas
Anybody know who carries the upper ball joint socket for Dana 44's? It's about an inch in diameter, with 4 tabs on the end to engage the slots in the threaded insert in the upper yoke. (like
a smaller version of a spindle nut socket).
I've tried Pep Boys, Autozone, the Lisle tool catalog, Sears, Harbor Freight, 4 Wheel Parts Wholesale....nada.
77TexasBronc
Baytown Texas
Got mine from BC broncos. Its listed on their web site under shop tools
http://www.bcbroncos.com/
72bronco
Same here, I got my ball joint and hub sockets from BC Broncos.
Got mine off the Snap-On truck.
Should be available on line at www.snapon.com
Sorry, don't have the part number or catalog handy at the moment.
Southerner
I made one from an old socket using a grinder. It wasn't hard and it didn't take long to do. Worked just fine. I knew there was a reason why I kept all of those old worn out sockets 8) ;)
70_Steve
Old Guy
Re: Re: D44 upper ball joint socket?
I made one from a new socket. Figured out what size socket I needed and bought a cheapy deepwell socket from the auto parts store. 10 minutes with an angle grinder and I was good to go.
E
eBronc
Austin, Texas
Got it.
It's out.
Went down to Harbor Freight, paid $1.99 for a 3/4" deep impact socket, used my grinder to shape the end to match the 4 slots in the ball joint insert, and out it came (after soaking in PB Blaster overnight, heating with a torch, and letting the impact wrench rattle on it for over a minute on full reverse).
That thing was STUBBORN.
By the way, the ball joint/U-joint/ anchor pin tool that Harbor Freight sells works GREAT. I had to use a breaker bar to turn the threaded shaft, but it popped out all four SEVERLY rusted ball joints and both front axleshaft U-joints with no trouble.
My custom hybrid full-width high-pinion 8 lug disk brake D44 front is coming along...
