Dana 20 bolts
johnbeck
I"m mounting my Dana 20 to the intermediate housing. I have the bolts but can't remember back two years ago, do they need split washers? Thanks (I spent 20 minutes looking through my Haynes manual to no avail). Which is the easier way, install the C4 cross member then the dana 20, or the dana 20 then the cross member? Thanks
Viperwolf1
electron whisperer
D20, then cross member. Use lock washers and thread sealant.
J
johnbeck
I probably should apply grease to the spline shaft that goes into the intermediate housing. Is Ford molly multipurpose the right viscosity? Any preference of transfer case fluid- I have to go out and pick some up. Thanks
bronconut73
If it's a Dana 20 TC then Ford called out 50wt non-detergent motor oil ....
I use Redline gear oil in mine (75/90).
Have for 25+ yesrs.
Some gear oils do not do a good job of protecting the Dana 20's syncro's(?).
Sometimes it's hard to find non-detergent 50 wt. motor oil.
blubuckaroo
Grease Monkey
Ridgefield WA
I've got over 300K miles on mine with Valvoline SAE 50 Racing oil.
I haven't seen anywhere the requirement for non-detergent. ?:?
