Hi guys,
I’ve been working on tearing down my Dana 20 to figure out the root of a nasty vibration I have. My Dana 20 is a ‘73, and has a Teralow gear set.
In doing so, I’ve found that the current washer/spacer had pressed itself onto the shaft, past where the c-clip was supposed to be (which was not installed), so I had to cut it off. Also, the front bearing was the complete wrong size.
Does anyone have a link to where I can buy a new one of these? I found this, but it’s for a Jeep Dana 20, and I’m not sure if our application is the same.
https://4x4.fatbobsgarage.com/mobile/washer-front-output-dana-20-p19473.aspx
Thanks!
Thanks!
