Dana 20 output shaft (damaged), is it unusable?
langester
MASTER OF MADNESS
Hello again,
I am working on my dana 20 (still), I took the rear output shaft out and pressed off the bearing. I cleaned it up and began to inspect it, I have a couple questions for the experts out there.
1. The outside 3 threads got stripped off when I removed the nut. Is this still usable or scrap iron?
2. looking at the gear end there appears to be step in the teeth, is this normal or is it scrap iron?
I am afraid I already know the answer, I have another case and the output shaft is cracked on it so I am out of spare parts.
Let me know what you think.
As always, Thanks in advance!
langester
langester
MASTER OF MADNESS
Sorry , the pics didn't post up. I must have hit the button to fast. Lets try that again!
NC-Fordguy
Bethel/Greenville NC
Will the nut thread back on? If it does you might be ok seeing how some thread locker should be used for final assembly.
I'd keep an eye open for a better one. Lot's of us will install a hardened shaft making the stock one surplus. If you wheel your bronco you may want to go to the hardened shaft route. I've broken a couple stock shafts over the years.
Viperwolf1
electron whisperer
I'd call it last choice useable. D20s are easy to find under $100. Keep your eyes open.
langester
langester
MASTER OF MADNESS
I appreciate the replies! Thanks Viperwolf1, I was hoping you would reply! I am working on getting another one right now!
Thanks a ton guys, I always appreciate the help!
TN1776
That output shaft is worn - most of them are. It is usable but I trust stock D20 output shafts about as much as I do gas station sushi and the man with the slicked back hair that sells used cars downtown.
I was a non-believer about how easy they are to break, until I broke mine. I upgraded to the aftermarket 300m shaft sold by WH and I still carry a built spare when I go on trips.
langester
langester
MASTER OF MADNESS
Thanks for the info. I was looking at the upgrade but my wallet is not willing to help me out right now. I have located a stock shaft for now , thanks to one of the members on here. I will get it and install it until I can afford the upgraded shaft. I have enough parts to put together another output assembly when that time comes.
Thanks again for the replies, I always appreciate the input!
Have a good one!
langester
langester
MASTER OF MADNESS
I got an output shaft today that is in new condition. Thanks to a Member of this forum, I can move along with the rebuild. I am not sure if the Member wants to be named, I just want to say "Thanks". I appreciate you going out of your way to help me out! This site is Awesome!
Have a good one!
