Chasing a non-op speedometer and figured out the green plastic speedo gear was loose on the shaft. Managed to get it back on the shaft through the hole for the cable gear using some brake spoons. Took it for a drive and it was off again. Pulled it out and compared it to a spare I had and not sure what I am looking at? I can't imagine this is factory? It looks like it was sleeved or something compared to the other shaft in the pic.
I guess my best option is to rebuild the one shaft I have with the steel gear? It was not in the best shape and has some pitting on the teeth in a few places of the speedo gear.
Or should I try to glue/loctite the green gear back on its shaft? You can also see the remnants of the shims I guess that were in there? Not sure if they ended up that way because of the gear being loose on the shaft or if I have bigger issues.
