Dana 20 Shift Bar Orientation
Bucky71
Hey Everybody,
First time poster here - thanks to everyone for the great info on here!
I just got done rebuilding my Dana 20 T shift transfer case, and have a question about the bent bar that connects the shifter to the shift rail flat bar.
There is a 90 degree end, and a slightly tighter angle on the other end.
Can you tell me which one should be attached to the transfer case side?
Thanks!
Chiclassics
The 90° bend goes toward the transfer-case shift rail/flat linkage bar.
The slightly tighter/less-than-90° bend goes toward the T-shifter.. Post some pics as well
B
Bucky71
Got it! Thank you!
I’ve tried to post pictures, but it seems like it will only work if it’s hyperlinked - not sure how to get it to work from my phone. 😬
gnpenning
Bronco Slave
Follow this for posting pictures. While there are other ways, this is the easiest. Even I can do it.
