WPBronco
I have a 68 with T shift Dana 20. 4 Low and 2 high shift work fine but it will not shift into 4H. I dropped the transfer case and took off the cover to get a closer look. THe sliding gear on the front will not slide forward. I took out the detent spring and ball on both sides and then I can get the gear to slide into position. What is causing my problem? Do I need new rails? Tried looking at a shop manual picture and I am wondering what job do the rods play into this? I have not removed the access hole screw. Is there an adjustment there?
thanks for the help
thanks for the help
