Hello fellas. So I had been noticing a noise and a little bit of a grind when in 4Lo. Today I lifted my Bronco, set it on frame stands and drooped the front axle down to check for driveshaft binding thinking that may have been my issue. Well, that was good, but I removed my drive shaft and when turning the front output shaft on the Transfer case it felt a little crunchy. I'm pretty sure my front output shaft bearing are bad. Is there any way to swap them out easy without removing the case and completely taken it all apart? I already upgraded the rear shaft with a WH HD Atlas style assembly, and it turns silky smooth. If it's possible and you got some tips, I'm all ears. Thank you
