sneditch
- Jan 23, 2017
- 54
Replacing axle seals on Dana 30 on my '69 Sport. I expected the "outer seal" to be between the axle stub and the spindle so a bit surprised to find these (image 38 is driver side, image 68 passenger) installed in the carrier tube ends. I googled the C/R 519034 and Trostel 124-5.25 and came up with references to Ford axle seal C6TZ3254B. I assume I am on the right track to replace them using these outer housing seals (http://www.wildhorses4x4.com/product/dana30_Outer_Housing_Seal/Bronco_Dana30)
To remove the old ones I am intending to use a seal puller and if that doesn't work then use a large socket on the end of a long extension to tap it out from the carrier side. Before doing either thought I would check with the brain trust here.
Also have a question on the appearance of rust in the carrier, including on the bearing seat, under the bearing caps, etc. (img 54, 22) I am concerned not to alter the bearing seats, cap seats, etc., but assume I need to clean this/kill rust to avoid any issues. Can I use rust remover, scrape lightly with brass brush, then coat with gear oil? Any other suggestions to clean or should leave it be and not risk altering the bearing seats, etc?
Sned
Sned
