Dana 44 camber shims
genteca
Has anyone found a source for the camber shims. I am finishing a ford knuckle swap and would like to use shims instead of ball joint ecentric sleeves. I will be taking to alignment shop for exact needs but I know these are hard to find. 6" OD and 4" ID. 1978 knuckles on 72 dana 44. Thanks
jamesroney
Fremont, CA
I'll let you know if I find anything, do you know yet what your needing. I have 1 green and 1 tan.
I've got a couple of shims in my stash of parts if you need one. I was saving them so that I could have them laser cut...but I kinda got lazy.
Now when I do a front end alignment, I just get the values from the front end shop, then disassemble the knuckle and then mill the knuckle face that exact amount. Then put it all back together and never need another shim. It's almost the exact same amount of work as installing the shims. But it's one and done.
Also, I recently did one where I was out 1 degree of camber on the passenger side only. But it turns out that the tube was bent. That turned into a little more work.
genteca
genteca
Hadn't thought of this route, now my wheels are spinning. What shims do you have?
toddz69
With all the requests for these things the past few years, there seems like there could be a bit of a market for them - particularly for the disc brake Ford knuckles.
Todd Z.
genteca
genteca
Todd Z.
My understanding is the labor to install the shims compared to ball joint eccentric caused them to not be used in alignment shops with minimal demand they quit making them.
blubuckaroo
Grease Monkey
Ridgefield WA
The alignment shop I used for my '77 chained up the axle tube to the alignment machine, and bent the axle tube with a hydraulic jack.
No disassembly/reassembly required.
toddz69
Interesting. I've installed both and found the eccentrics to be more time-consuming as I had to take the knuckles loose to remove/install.
Todd Z.
toddz69
Very interesting. I know they do that (or used to do that) with the Twin-I-Beams to align them but never heard of it with solid axle trucks. Would work though!
Todd Z.
Yes to the Chevy conversion, no to the Ford.
They’re designed for the six bolt spindle, which is what the Ford drum brake and Chevy disc brake kits use.
The Ford disc brake set up is a different size and number of bolts.
Yeller
Rogers County Oklahoma
This or heating it to create a pull has always been my fix. But I do it when building the axle from scratch with an alignment bar checking for straightness.
reamer
