Dana 44 carrier
moses_m
Is this an open carrier? Pulling the triggers on some 4.56 gears. Thanks in advance too all who have helped me on my upgrade.
moses_m
moses_m
Has these markings on it.
Just from pictures it looks like a soft locker. Where should I find markings?
krashnpa
Mounted Joy, PA
It is a detroit... Also looks like it's a 3.73 & down carrier so your 4.56's won't work. The markings on the r&p say 46-13 which is a 3.54 ratio.
broncnaz
If it had high gears ie 3.72 down I believe its a 3 series carrier so to keep it you have to buy thick gears or buy a 4 series carrier and standard 4.56 gears.
moses_m
moses_m
just to confirm it does have a 46-13 mark 3.50 gears.
So 4.56 thick cut gears will work will this carrier?
garberz
Bronco Influencer
Conejo Valley, Ca.
Nothing better than prying off that cover and hitting the jackpot. What a great surprise. Yes, just order up a thick ring gear and pinion. 03' -06 Heep Rubicon is the application. Nice score moses m.
Mark
moses_m
moses_m
TTT
ordered parts should get here this week.
Whats a reasonable price a shop should charge me for installing new gears?
Will be dropping off dana 44 with 4.56 thick gears and toms dana 44 install kit part#3515
broncnaz
Reasonable is subjective. Very hard to say what a shop will charge you. All depends on the shop and how much they charge if they go by the book you may be looking at $700+. If they do a lot of axle setups and are good at it you may be looking at $2-300. If you have a lot of shops around then Id get quotes see if there is any big differances.
DuctTape
Bozeman, MT
TTT
I had this done recently. ~8 shop hours to change gears and install a truetrac. Rate per hour will vary.
moses_m
moses_m
Dang 700 is a lot and 8 shop hours sounds way too long for a gear swap. If I get quotes over 700 I will just return gears and kit, sell the current dana 44 I have and buy a freshly rebuilt dana 44 from toms $2600 with the gears I want and pay the 150 on shipping?
l
broncnaz
If the shop you take it to goes by hourly rates. Id strip it down pull both axleshafts that way all they have to do is mess with the gears. Otherwise they are going to have to do that work as well. that will cut time off it.
If the shop does a lot of ring and pinion swaps then the price is usually cheaper as they know what they are doing. It can take a lot of time if someone is familar with the process.
Justafordguy
I can do that swap in the truck, on the ground, in less than 4 hours. Don't let them charge you 8 hour labor.;)
broncodriver99
Glen Allen, VA
The 9" is a breeze. The D44 not so much. If both your old and new gear sets have pinion depth markings it gets much easier and with a proper pinion depth tool and set up bearings, you can usually get one together with an acceptable pattern in 2-3 tries. The problem with the D44 is in order to adjust pinion depth you have to remove the carrier and inner bearing race. It gets very time consuming. My first one took me 2 days. After that it gets faster.
moses_m
moses_m
I just need the front done I bought a complete third member for the rear.
broncnaz
Problem is your not a shop. You deal with your own warrentee work and customer satisfaction.. Most shops have a book or probably a computer now that tells them it will take X amount of hours to do the job. So thats what they charge even if there's a short cut and they can do it in half the time. You really cant tell them they cant charge you for 8 hours if thats what the book calls for. On the flip side if it takes them longer than the book says then they eat it.
Of course if you can find a shop or someone that setups diffs all the time then the price is likely to be lower.
moses_m
moses_m
Going to spend more money and buy a rebuilt dana 44 with the gears I want in it. Going to sell or return all the parts I have. With the quotes I received and 2 days of missing some work to drop off and pick up differential just doesnt make financial sense to me anymore. Thanks for all your help.
