Hey All,
First off I am very new to building an early Bronco so please forgive my lack of knowledge. I am working on figuring out exactly what I'm working with before pulling off the tub. So started looking at my Dana 44 and found that I have flat top knuckles with high steer from what I'm able to figure out with my limited knowledge. My goal with this rig would be a mixture of daily driver and off-road uses. I am attaching pictures and am hoping for some feedback on the current setup.
The planned build would be as followed.
* Lift - Wild Horses 2.5" Suspension System with 1" body or
* Transmissions - Gearstar Ford AOD
* Motor - 365HP 365FT LBS from BluePrint Engines with Holly Terminator Stealth.
* Rear End - Wild Horses Super 9 Housing Axles and Custom Built Third member with Eaton Truetrac Differential w/ 31 Spline and 4.56 gearing.
* Front End - Rebuild the Dana 44 with Eaton Truetrac Differential w/30 Spline and 4.56 gearing.
* Tires/Wheels - BFGoodrich KO2 LT285/75R17 US Mags Indy 17x9
Plus a long list of other things to ready this rig for another 50 years ;D
So questions if I may.
1.) Is the flat top worth keeping or would it be better to go a different route? I like the Front Disc Brake Conversion Kit, Dana 44 from James Duff?
2. The High Steer rod end are pretty rusted so and suggestions on good replacements?
I appreciate any info on this.
Jeff H
Jeff H
