The innermost seal (the axle shaft seal way down the tube at the differential) looks like this:
https://www.wildhorses4x4.com/product/dana44_Inner_Axle_Seal/bronco_Dana44
This should be the only style used in a 44 of Early Bronco vintage.
The pictures I see of your "SKF 13165 inner seal" number listed above appears to be this type.
There is no seal at the outer end of the tube, such as you might find on some Dana 30 axles.
The wheel bearing seal (back of the bearing hub) is commonly referred to as a #4250 but some manufacturers use different numbers. But 4250 should cross over.
Your "SKF 24917 outer spindle seal" looks suspiciously like this seal. Best to double-check unless you already know that this is the wheel bearing hub to spindle seal. Consistent with being an "outer" seal, but with the wording these days it's not always easy to tell what the manufacturers are putting in the computer listings!
As the others have said, the actual seals used at the back of the spindle were of two different types. Even the spindles included in the GM disc brake conversion kits can vary between the two as well. However you are often limited to what type of spindle seal was used originally, so that the axle shafts themselves are compatible.
So look at the back of your spindle to see which style is already on your rig.
If it's a large press-in type seal (looks similar in size and style to the #4250 above) then you need one that looks like this:
https://www.wildhorses4x4.com/product/Spindle_Seal_6672yr/bronco_Dana44
If it appears there are multiple components back there, then you have the 3-piece setup including a small seal that slips in over the spindle bearing, a larger flexible V-shaped seal that floats there between the spindle and axle shaft, and the thrust washer either made from bronze (original) or plastic (aftermarket) up against the axle shaft flange.
Even if you don't buy from us you can still see images of what each component looks like on this page here:
https://www.wildhorses4x4.com/category/bronco_Dana44/a
Hope that helps.
